Hub Size?
DiscoStew
I have a line on a set of snows off a "03 eclipse or a 99 prelude" with steel wheels and the correct bolt pattern. How can I determine if these rims will work on my Mazda5 hubs? Do I need to worry about offset if the tire width is OK (205/55/16)?
Thanks!
- Stew
Also, be sure the steel wheels are not HONDA OEM. Honda uses round seat lug nuts instead of standard acorn lug nuts. If the wheels are Honda, you will need their lug nuts too, or tragedy can occur.
Thanks
Turns out the guy was full of cr4p. Tires didn't match in size, some mounted, some not... sigh. Classic Craig's list. Search continues.
