late to the game again.
i have read althe way through but this caught my eye on the scrolling first. I do not know alot and much of is from reading and not hands on. Mostly theory I barely grasp in regard to suspension and steering geometry and such. Something about axle centers. Even if you adjust camber to bring the wheel back to a more vertical position from negative camber. The relationship between the height of the shaft at the motor and the shaft at the attachment point to the wheel has changed. This change of, setting the car lower, can start to affect steering geometry and how the cars transitions the loads from corner to corner when driving. Like I said, way above me, but I think there is more to it than just camber adj. I don't mean to sound rudeThe more you lower the car, the more you are going to get negative camber (the splaying of the rear wheels). The only real problem with too much negative camber is excessive wear on the inside treads of the tires. You can take care of some of this by rotating often or, you can buy adjustable camber arms and have a shop set it for you.
