AutoXRacer
Yes, i recall you speaking of the full throttle flash. Thank you for the clarification about the fuel / boost cut. So do you consider the flow increase, creating a little more boost to be the problem. or maybe more of a combo of signals referenced by The sneaky Mazda ecu Thanks hope this is not a terrible question.
Talking with CP-E and monitoring my sensors and logs, I believe its my boost profile. My boost is not following the "stock" boost curve, so the ECU is triggering the safety. Of course, everyones results will be different. I have no restrictions in my intake and exhaust flow paths...none what so ever. The throttle plate was my only restriction left. So when I was able to open that to 100%, the flow...therefore, boost curve is much flatter and no longer matches the ECU's preprogrammed curve. I'm basically holding higher boost in the upper RPM band.
But my issue is the same as all the other guys that have increased their boost with MBC or whatever and triggered boost cut...I just did it with stock boost and an unrestrictive flow path.
I hope that helps and I didn't go off on a tangent... (lol2)
