I did take the clamp off but it still wouldn't budge. I could only move it a little bit but it wouldn't come off.Did you make sure the clamp was off the intake tubing?
That rubber tube gets stuck on there pretty darn good. Just make sure the clamp is loosened enough and give it a yank. When I put the CAI in the P5 I had the same issue with the stock intake. Just pull from the driver side and wiggle it a bit, it'll come off![]()
Yeah, its cracked anyway so its needs to come off.
I found one on ebay for 30 bucks.
Hahaha why would you do it yourself if it's covered under an unlimited warranty. In my old 02 Protege would also stall out when I would idle. It would cost $300 plus to get it fixed at a garage or have to pull it apart myself and clean it like most of you but I took it to Mazda and it's covered under an unlimited warranty. The EGR is faulty in the protege. Therefore, they fix it or replace it if needed, FOR FREE
Not sure if the warranty stuff is different in the USA but that's what it is here in Canada haha, go check it out.
My rough idle is back...
Does anyone know what phone number to call to see if US cars are covered under this EGR "unlimited" warranty? I'm sure calling a dealership will have mixed results, might be best to call the company...
yeah, my car has been hauling a lot of ass after I replaced the EGR valve with the new canadian one... it still ran bad at low speeds because the plugs were still fouled up from when the EGR was bad, but I cleaned them up and it's all good
Is there a different part # for the Canadian EGR? Maybe I can bounce a group deal for anyone interested since I'm in Canada...yeah, my car has been hauling a lot of ass after I replaced the EGR valve with the new canadian one... it still ran bad at low speeds because the plugs were still fouled up from when the EGR was bad, but I cleaned them up and it's all good
I just got off the phone with Mazda North America and the local Mazda dealership, and they both say there is nothing about any unlimited warranty for the EGR in our cars. There is a technical service bulletin, but it only instructs the technicians on how to diagnose and service the issue.
Looks like we're on our own with this problem. (boom07)
