- 2003 Subaru WRX Wagon, 2000 Miata
hard to see my wires cuz i have too much red in my engine compartment!
anyways, you can see that the terminals are covered with yellow rubber boots. i used 8AWG wire.
slenser said:Are you measuring the shielding as well? I measured only the wire itself.
got wake? said:post pics of each spot you grounded, and the battery. the only way for the grounding kit to cause your battery to go dead is if it's tapped into a hot wire, or the positive battery terminal![]()
fLyPiNoY7 said:from chopstick's pic, i was wondering if this place on the transmission is suitable for mounting some grounding wires on it...i havent seen it get grounded in any other pics so im not sure about that...
