to sum it up Im pretty sure I tossed some screws threw the motor, and posible spun a rod bearing. I definatly fried the s*** out of the piston rings ect.
Heres what happened. Since day 1 Mobile 1 with .3 qt of Lucas oil Stabalizer (after the 3.7 of oil, to keep her from starving the 4th piston in corners) and changes after 5k (kilometers, not even miles) I also whent for the gold in tranny fluid.
Im in line at Tim Hortons waiting in the drive through & I notice the snow steeming off my hood a little more then usual and thhe temp guage a tad higher then usual. I pull over and check the oil the dip stick is bone dry, and the b**** is a Qt and a half below full (thats how much it took to get her full) after cool down. I was very surprised as she had the oil changed 3k before, & I had checked her after 2k. So this ment I lost a qt and a half in 1k of normal driving.
I heard the motoor was known to drink a little oil, what motoor doesnt, so I decided to keep e even closer eye at the oil. I did a full change and kept a eye out. 3k go buy and all is normal, well Im at full, so it apears as if shes not heavy drinking the oil anymore.
1.5k go buy and I hear a weird sound as I pull a U turn. Its a sound no car owner wants to hear, a LOUD tick as she revs and going with the revs. I also notice thhe oil light flicker for a sec then go off as Im doing this U turn. Her temp is perfectly normal.
I check her oil...... BONE DRY I have oil in the trunk I toss it in and the LOUD tic subsided to a low tick.
I looked at the car and said "Im done" Whatever the **** thhe issue is, even if fixed throughh the warrenty, the warrenty wont be thhere for much longer, and there hasnt been anything to fix these common issues other then to fix whats broke untill it breaks again.
I personaly drive my car a little harder then most, but I also maintained my car alot more vigorously then most, and these issues should not of hapened, and when I think "had this been a Honda I wouldnt be in this situation", I get pissed off.
So I havnt even taken the car in to Mazda yet, Im selling off my performance parts then bringing her in for warenty work and selling her after.
Ill always miss her, & always wish Mazda made the FSDE a little tougher.
