red wire should go to the ignition harness. anything else, the airfuel ratio guage would stay on all the time. the gauge will only stay on when you turn the key to on. thats what you want. the wire in the igniton wire is about a 16 gauge wire and the color is black with a white strip. ill try to get pics.
i grounded the black wire to one of the nuts holding down the ecu plate. thats easy because you do not have to make a new hole.
for the purple wire. i took out the ecu and i was trying to find pink with blue stripe. no luck, so i took the black plastic piece off of the ecu harness and it exposes all the wires conected to the grey piece. every wire is numbered and it is very easy to find number 60.
i did not have any butt connectors, so i just twisted the wires together and put electrical tape around. it seems to work fine, it should not be a problem.
if it comes out to be a problem, ill put butt connectors in.
