i installed mine today but the air fuel only has one green light on the rich and i connected it to the first 02 sensor in the engine with the pink and blue wire...whats wrong?
for everybody trying to find a switched power for their gauges, check the fuse box. i dont know why everybodys trying to tap into the ignition wire. get a test light and find a fuse that only works with the car being on, such as the fuse for your gauge cluster (which is where i have my radar detector hardwired with no problems) you could also use the room fuse (what my headunit is wired to, again no problems with switched power there)
also, its a lot simpler, pull out the fuse stick the wire in the power side of the fuses location, shove the fuse back in and look you have a fused, switched power.
i just installed a prosport a/f gauge and it sits at all the way lean and doesnt budge. before I connected the green wire to slot #60 it used to sit at all the way rich... everything else works fine with it as far as lights and opening ceremony....
any suggestions?
i will mess around with it this weekend and let ya know how it goes and what i did. I was told by someone that if you touch the end of the sensor wire that the needle should jump around. makes for a good test to see if the gauge is good.You might want to try splicing into the air sensor in your exhaust manifold instead of pin #60. I spliced my air/fuel gauge into pin #60 and my gauge does not work at all(could be other problems), I am going to try and wire it that way my self an see if it works better.
I got everything hooked up but nothing is on???
