Blade4804 said:does OBX header fail inspections in texas? visual or emissions?
Blade4804 said:I got this header used and noticed that the thread on the EGR connector that connects to the egr pipe, broke or got bend outa shape, only on the first two lines... but enough so i am not able to get the bolt to connect the EGR pipe to fit. is there a shop I can take this too that can clean up the thread or even restore it? or do I have to find and old header and have the shop cut that off and reweld it to the OBX header so i have a good thread to connect to?
Bala de Plata said:My EGR threads got bent out of shape during the original install. Pick up a small triangular diamond file for a couple bucks at a hardware store and try to clean up and reshape the threads. Mount the header loose to the head to give yourself a little "wiggle" room and thread the EGR fiiting using a little 3in1 oil. Screw it on, back it off, add oil - repeat until it's all the way on. THEN ... snug down the bolts to the head @ 14-16 ft/lbs. Take your time, it will work!
Edit: Image added
Blade4804 said:ok will try that, did you get your ceramic coated? or chromed? mine is like all purple and stuff..
Boston5761 said:tad off topic: does this look like a real obx to you guys?
http://www.msprotege.com/forum/attachment.php?attachmentid=87722
don't use their gasketdamaster said:I got 2 gaskets with my OBX header: one is at the mani end but where does the round gasket go?
I was able to reuse my stock "donut"Kansei said:it goes between the header and midpipe. It replaces the one that will come off with your stock exhaust manifold.
edit: beat to the post
