One last thing, for those who are interested in making their own kit .. I'll try to make life a little bit easier for you.
Here are the items you will need to buy:
1. 14-16 feet of 4 gauge power wire
If you want yellow, discountcarstereo is the ONLY website that still carries it, and you better hurry if you want it cuz Stringer discontinued it.
http://www.discountcarstereo.com/detail.aspx?ID=284
2. 20 gold (24K) plated ring terminals
If possible, do NOT buy Stringer terminals cuz they're a pain in the ass! The rings aren't wide enough for a lot of the bolts (12 mm, 14mm, 17mm) so I had to dremel mine to widen them. Not a big deal .. but kind of a pain in the end.
3. Postive/Negative 200-series Monster battery terminals
Look on eBay, you can pick up both for $20 or so.
Here are the measurements of each wire as well, so you know how much to cut for each one:
1st wire: 18 inches
2nd wire: 14 inches
3rd wire: 11 inches
4th wire: 14 inches
5th wire: 18 inches
6th wire: 16 inches
7th wire: 18 inches
8th wire: 24 inches
9th wire: 11 inches
10th wire: 14 inches
The wires should roughly look like this, 1-10 from outside to inside / right to left (switch 3 & 4 and 4 & 5 should be longer .. I messed up so learn from my mistakes).
As always .. PM with questions and good luck with the install.
