jmv said:hmmmm..... i read like 16 at vacuum???? My boost seems like it would be right, being at 7, but i have nothing to reference to check it.... any reason my vacuum reading would be so low??
Easy... either you have your A/C on, your defroster on, or you have a vac leak. If it is the latter and you have stock hoses, you need to look around your T's. The stock T's crack easily. Most likely that is where the leak is. You should get it fixed. For starters, replace all your lines with silicone.
