Ok So working on some small stuff. Finally cut my EGR pipe. So now im running a filter on it with the header side capped.
Still working on my gauge pods. decided to delete the A/C controls. =) Still need to redo the switch side make it pretty.
Found out that my header is leaking between the two pieces. =( Going to fix that and double check the rest of the exhaust. Also gotta fix my damn O2 sensor for the wideband. The threads are messed up.
4-13-11 Test fit the panel. I want to pick up the new Prosport Evo boost gauge.
Also my wife threw out the box that had my straight neck housing for the thermostat. I was going to do that today along with the new water hose from SpeedCircuit. =(
