J Justin2129 Member : 2002 Mazda Protege 5 May 3, 2012 #1 Just hooked up the H7 Hid kit from DDM tuning. when i tried it out the right side lights up for a few seconds and then cuts out; other side works fine
C Clarkbug Member : 2003 Protege 5 May 3, 2012 #2 Try and swap the ballasts (or bulbs) from one side to the other and see if the problem moves. Could be a bad bulb.
J Justin2129 Member : 2002 Mazda Protege 5 May 3, 2012 #3 i did and the problem followed to ballast...would it be fixable, or will i just have to get a new one?
X xitoxic Member Contributor : 2003 Protege5 May 3, 2012 #5 if they're flickering i guarantee you its just the plug ins. those 2 things that slip into the 3 prong plug in. when those wiggle around it makes the light bulb flicker. If they're brand new nothings wrong with them
A aniel Member : Mazda 6 sport 2004 May 4, 2012 #6 check the relay and check if the power is coming to the plug which goes to the bulb. _________________________________ tomorrow is the first day of the rest of your life! uobd2.com
N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 May 4, 2012 #7 if the problem moved with the ballast, you need a new ballast.
