The weather finally got warm enough to get some work done. Hoisted her into the air, pulled and calibrated the wideband O2 sensor which I hoped would correct some surging I had when I took her out the other day. Then I moved to the rear.  Removed the lower diffuser and my temporary muffler hanger (which had been installed for something like two years). I then set up the new hanger I bought:
I need to buy myself some proper ViseGrip welding pliers to make this easier the next time. I didn't have any stainless stock to practice on and my first attempt (which was vertical) was barely good enough to get it stuck in place. I ended up removing the muffler to do flat welding. Not the best I have ever done but it's solid and only ended up a little off-set:
Once that was done I put it all back together. I forgot how much of a PITA a couple of the screws at the back of the diffuser were to get in place. I literally was straining to put the middle one on the passenger side together. If I did any sort of bulk exercise I would have been screwed. In any event it is all back together and as can be seen, the muffler is well clear of the previous impact zone on the diffuser:
		 Y'all gonna have to wait until September or thereabouts to find out just what it is.
 Y'all gonna have to wait until September or thereabouts to find out just what it is. I bought my door bushings from him, I posted his Instagram a few posts back. He's in Greece and has started producing some parts for Miatas (he has an NB). He is working towards a website but for now everything is via his Instagram.
