Help with Wheels
mzballin
Okay so i painted my set of winter rims---
i cleaned them insaneley, then sanded them down, then gave them 2/3 coats of primer, then like 3/4 coats of BLACK WHEEL** PAINT, and then one clear coat.
however, im about to paint my summer rims and i was wondering since i cant find gold wheel paint from the same company that i used on my winter set, i was wondering if i could just use high heat engine enamel and it will still work fine? ? lemme knoww...
Thanks alot !
Or you can just use duplicolor or any other gold as long as you get a few good coats on them and finish with an automotive clear or engine enamel clear.
