HELP: strut Rear Clunk
have had my P5 dropped since beginning of this year and I have had this clunk in the rear that has really been pissing me off. i have about 50K on the stock struts. have checked out all bolts, on top of the strut, bottom and end-links look good......
the sound sounds like it is coming from upper part of the start?????
anyone else have this problem with eibachs with stock struts?
thanks.
-Ace
  • Like
Reactions: L8R
I have the same problem too. I dropped the car two cars back with TEIN but has gone back to stock a year after. The noise is annonying and only happen when I go over bumpy roads. I feels like the suspension is going to fall out or something...
The nut going to the upper bolt????
It only happens when i hit a big bump when the strut compresses or releases fast.......sounds terrible......
i found nothing loose???????
this was discussed before. do a search. put a washer under the nut at the top of the strut. the 17mm one i believe
Washer under the nut like so:
thanks. i did a seach and really could not find an answer.......maybe this sunday I will try this.
thanks jackson......
I am thinking that also. Car is not as firm as before but I'm not expecting much after 86k miles of driving... On top of that I still need to take care of the timing belts, brakes are getting bad, tires soon needs to be changed... I'm starting to look into the option of getting a new ride instead... opinions?
mopiko said:
Wow, that's cool, 3 people got helped in one thread! Nice!
have wanted to post this thread for some time now......
brakes are easy on our cars.....did all four wheels last weekend. timing belt is not that bad i heard. i have another 40K or so to worry about that.
i go through my tires fast........winter tires will go on soon!
Yeah, Brakes I can do myself, I've done the fist set myself back at 40k miles. Timing belt is the monster though, at least with my limited knowledge on cars I don't think I can attempt it by myself. Good thing my girlfriend's brother is a mechanic so he can help. I asked a dealer about parts (time belt, drive belts, water pump and head gasket) and they quoted $250!! Man I'm going broke....
... and yeah, winter tires for me too, last year I got stuck with my "all-season"... Looking at getting a set of Bridgestone Blizzark...
$250 seems good for all that work.
bridgestone makes ngret tires.......
I'm hoping the same thing too. Where can I get the washer?
lowes, home depot........
i might try to do this tomorrow.
i did not get a chance to try this this weekend.
i think you can do it without dropping the assembly?????????
will let you when i try.......
