help meeeee lol na just have a leg question need some pro help!
Secto1
mazdaspeed
i have alot of boost lag in 3rd 4th and 5th in about 4 rpms it holds and moves verry slow (talking about the needle)even if i floor it i hear alot of air from my intake its like shhhhhhhhhhhhhhhhhhhh then the needle slams wtf is wrong its a non flashed ecu also should i flash it or what can i do all my pipes are tight can there be a leak???
i need alot of postive feed back thanks!
It's possible that you have a boost leak in the vaccuum lines. It just sounds like you're experiencing hesitation though. Any more details on this like when it occurs (after longer driving times, just when you start the car, etc)?
like in the mornong my car halls ass goes through all gears no problem but after a while it lags even if it sits for a while it lags its like it goes until it hits about 4000 rpms then it sits there for a few then slams its like the cars not boosting right.
...and heatsoak due to the small I/C. If you really cannot stand it, go get flashed. Just be sure you can't stand it because that limits your boosting levels until you get a standalone.
go for a boost gauge and a boost controller(please don't be like some people and turn it to 15psi without supporting mods), if you know what you are doing.
i forgot to mention that i have a greddy type s bov attached to the custom charge pipe can this cause a problem my bov is addjusted to hard no stalling ?
