Help me: Replacing interior dome and map lights
IAATM
2013 Mazda5 Sport
I vaguely remember somebody posting a link to a video which demonstrated how one goes about replacing the bulbs for the map and dome lights, along with some info on purchasing HID replacement bulbs.
However, I can't seem to find those videos anymore (either here or via Youtube).
Can you please point me in the right direction?
FWIW, this would be in a 2013 Mazda 5 sport, a USA-spec model.
Hi,
you can find on YouTube Mazda 3 LED bulb replacement instruction, same for 5.
For the dome light you just pry the while glass open with a plastic pry tool, there is a small notch there.
For the map lights use either plastic pry bar or a flat screwdriver, on the side of the light you need to press on the metal clip and the light will slide out.
