HELP!! HKS Turbo Timer Install issues
Didn't realize they made noise at all!!!! Mine just beeps during the countdown and flashes from white to red. I'm going to put some red film on the lcd display so it's red all the time and probably use a pigment marker to color the buttons red. tah-dah, then everything matches..... but seriously, it's annoying when everything in your car is red and then you see this bright white light when driving
Hey Gang,
I need HELP!!!!!!! I have the same problem as Les, but mine IS hooked to the ebrake and it does turn the unit off when the ebrake is released. What can this be??? it ONLY has 4 wires for petesakes!
So key on, everything works, Key off unit turns off with key. Ground is good obviously since the unit turns off when ebrake is released. have constant 12v with key off from blk/red wire. 0vdc from both Acc and IGN wire with ign off. What can it be? or is the IGN wire still suppose to be 12v with key off?
