Fuel door stuck!?
03.5 MSP
went to get gas this morning on my way to work & the door release on the floor wasn't doing anything!
tried to pry it open carefully but it wasn't budging...
need gas ASAP too! how do i get the damn door open?
No resistance whatsoever? Might I suggest having someone pull up on the handle while you attempt to manually open the door? I had that problem on my first car and that's what I had to do to get the fuel door open. Or jam something under the pull handle.
yeah when i pull the lever on the floor there is nothing whatsoever... but good suggestion! i'm gonna give it a shot in like 15 minutes
If there's no resistance, you've probably got a broken or severely stretched cable, but it may just be the fuel door spring and in that case, doing what I suggested would get the door open.
same thing happened to my trunk release. Im not sure if they use the same type of release but something came loose where the latch is on the trunklid. Just snapped it back in place and it was fine. It was a while ago so I don't remember exactly what it was that came loose. Hopefully you figure it out soon. Good luck
did exactly that - pulled the floor lever at the same time as trying to open it manually, worked perfectly. works normally again
Fuel door spring must have bound somehow... Hmmm.....
