Fuel differences
2001 323 Astina SP20 (P5)
Hey, I found this interesting article about fuel differences between Australia and North America...
In Australia, the Research Octane Number (RON) is used to indicate a fuel's octane. This number is derived from tests on an engine running at a constant speed of 1500 r.p.m., conditions that do not closely relate to those found in real situations. In order to address this disconnect with reality, the Motor Octane Number (MON) system was developed using a tougher test carried out at higher engine speed and temperature. In the US and Canada the two systems coexisted for a while -- causing much confusion. To resolve the matter the U.S. Cost of Living Council (CLC) index, better known as. Anti-Knock Index (AKI), was introduced and is simply the arithmetical average of RON and MON; so AKI = (RON + MON)/2 and is the number now familiar to motorists in the USA and Canada. Yet another measure may sometimes be referenced: Road Octane Number (RdON).This is considered the best predictor of octane but it is determined by running a vehicle on the road or using a chassis dynamometer, and it is too dependent on the actual engine under test. RdON is so close to AKI that they are often used interchangeably. There is no direct correlation between RON and MON, different formulations for fuels with the same RON number might well produce different MON's. You can make a rough determination, however: for the high octane fuels we are concerned with, the difference between RON and MON, or the "sensitivity" as it is known, is about 10. If you know the AKI therefore you can add or subtract 5 to determine the approximate RON or MON respectively.
So guys, our 98RON premium unleaded is the same as the yanks 93RdON unleaded, 95RON premium unleaded is the same as the yank 91RdON unleaded, and 91RON normal unleaded is a (no) and (blarf)
yay. looks like you arent special!!!
well actually, compared to california you are, since we dont even get 93 (RdRON)
Yes, our fuel is crap.....
And getting 98 RON is harder and harder where I live, and freaking expensive.
Good onya twilight for getting to the bottom of that.
All we need now is some Japanese servo's.....:)
from what i saw, japan uses RON rather than RdON...so 100RON fuel isnt much more than 98....but still we have pretty good fuel overall now that 98RON is available.
