Looks pushed out underneath your headlight and around the fender\wheel well that part is always the 1st panel to not look flush. Just take your bumper off and see why its pushed out (hopefully was just loose and needs aligned and tightened....however if this car was in an accident and things dont align the way they should you will have to get creative to make it flush if the frame isnt straight (washers, a die grinder, and a sledgehammer are usually all you need)...but again..hopefully it just needs taken off and put back on again.
