xelderx said:That is what I understand. What we need to find out is how much of the MPI's graph is useless to us. At what loads/RPMs does the ECU switch to open loop?
IIRC, if you're above ~4500rpm or so, you're in open loop no matter what.
Also, if you're above maybe 70% throttle, you're also in open loop no matter what.
I recall it being along those lines.
With a good OBD-II scantool and an hour of playing with it, you'd be able to narrow down approximately what conditions would bring you into open loop.
