Bigg Tim said:Crazee D -- how's the progress after you got accurate instructions from Nick?
I returned my unit with 1 brown and 1 white wire and got one from nick with 2 brown wires and new instructions that say 'long and short brown' where it used to be white.
Re-installed NA module and tried to find good places to mount the MPI and NA units and still be able to properly return the ECU to its home.
I hooked up laptop 1st time and could not get comm ports set up.
When I tried later I just needed to change the advanced settings on the USB to Serial adapter driver to look at port 1 or 2 since it said 3 and 4 were in use. Selected port 1 and then opened MPI tuner and set it to port 1 also.
Bada bing...live data!
Which I hope means we hooked everything up right.
Yesterday I noticed a sound that I assume was misfiring. Like pop, pop pop from the engine. I can really feel it too now with the motor mounts in!
I did 7 datalogs, mostly at idle and a few driving around and sent them off to Nick. He sent me a new fuel map to load. Now I gotta mess with that.
1st attempt to load map failed, I think file was renamed with wrong extension (.smt.txt) need to modify and re-attempt
