Fortin EVO One questions
Phoenix
2021 signature
It seems the Fortin Evo is one of the 'go-to' remotes here. Like some others, does the engine shut down when the door is opened, brake pedal or brake pedal is stepped on?
With my compustar, pressing the brakes temporarily turns off the engine while control transfers to the key fob, but I found that hitting the stop/start button twice will keep the car running with no interruption when stepping on the brake and putting it in drive
It stays running if you open the door. All you have to do is get in and press the start/stop button and off you go.
The only time it stops is if you hit the brake pedal before the ignition button (which you will do many times :) )
