patty AT forge
That would be flutter. Engine vacuum alone is enough to open the valve with the red spring so ****in theory**** it is fine for any set-up and boost levels on these cars.
In practice it is a bit more complicated. Ideally you do not want flutter but if tuning out the flutter leads you to use a spring that is too soft then the trade off is slower boost response and potentially lower boost levels.
Think about that for a second... what is causing the increased spool time and the boost to lower? Its a leak. Now turbochargers are feedback systems. Diverter valves and blow off valves ARE NOT boost control systems. If spring tension is causing your boost to lower than the boost control mechanisms (wastegate, solenoid, etc) are still trying to regulate boost to that higher level. This means that your shaft speeds are drastically increased to make the same boost level or in extreme cases LESS boost. This is terrible for turbo longevity and once the turbo ends up operating outside of its efficiency range it can have a detrimental effect on engine life also.
The flutter you are hearing is caused by a pressure differential of a few psi and isn't really something to be concerned with. That being said if you notice no performance difference with the blue spring and shims go with that arrangement. If there is no difference go with the softer set-up.
