How many times have you data logged and loaded new files? When do you know you are done. I am done with my mods and have data logged and recieved new files but how do you know when you're done tuning?
mykflo...
Currently on file 4 not including the base file, throttle responce sorted out, cam timing making the car pull lower all the way to the raised limiter, the driveability of the car is completely different to the stock car, so much more responsive and quicker off the mark and through the revs, with the 15" wheels on ( i use them on the track ) its like a "go kart" the 17" i run daily take the edge off it slightly but its still faster accell than standard from the 74bhp to the 88.5bhp last time on the rollers, had two more files since then should be up near the 100 by now....
Shaun......
There's no way you're going from 75 -> 100 bhp from a remap.. But I don't doubt the difference in drivability is huge.
I'm on the group buy and just waiting for the software and my first file so I'll definitely chime in once I start the tune Chance77.
Chance77
you should be able to revert back to the previous file with no problems ? I've been back to my base file to let a friend drive the car then loaded in the latest one, did a few miles to let the STFT & LTFT settle back down the let him have another go in it, he couldn't believe the difference from stock, iam sure Joe or one of the engineers will give you a lift if you give them a shout ?
Shaun.....
After my base file i started getting a misfire on all cylinders and running lean bank one, i can not get the program to load the pids correctly on a windows 8 acer. I have went through the instructions numerous times, but everything saves as .csv and i am told that my logs are missing much data because of pids being incorrect. I also need someone to verify i can return to stock as im being advised against it," never go backwards"
Im not saying anything bad, as it seems to be my fault that i cant load a simple program correctly, but the misfire has my vehicle near undrivable, and my 100 mile commute feels unsafe, also losy 8mi a gallon off last 7 gallons, no WOTS, easy driving cause of misfires. I already have checked vacuum lines, my MAF is seated properly with no play, and see no fractures, the only mod i haveade in last 20000 miles, has been the tune, previously, no misfiring, no lights, no running issues.
in the first place, you do not have a stock file to go back to, as we have not sent you one. I do not suggest you EVER back up, as it can cause some very large issues later down the road. Most times this has had to do with simple confusion about where the data came from and which file is loaded at any given time
second, we cannot confirm anything, as the data you have sent is missing about 95% of the information we need. seems to be an issue with the Windows 8 laptop version you are using. I will fix it this afternoon when I remote your car.
Now, the issue you are having is DIRECTLY related to the CAI your running. Why did it not show up before? Simple really; the base files are set very flat, and retarded so we can correct the load to 100% perfect. It is the very first step that has to be done BEFORE we can even start to adjust anything else. And when we set the Load compensations flat, and flatten out the requested fuel, any thing that has been changed in the air stack/path, will come out and show it face. in your case its the in correct flow design of the CAI.
in other words, the factory calibration was masking the fact your load was hugely off. We will correct this first, then proceed with the adjustment of your other tables. it generally is not a big issue, but with the issue of your data not being useful since its lacking the info we need, it has been a bit compounded
Hope thgis answers some of your questions. i loo forward to fixing you log issues remotely this afternoon
