I've seen a few posts in the past about peeps wanting to know how to do this. I just did it today, it's very easy. This will probably not work on cars that have daytime running lights.
First get down by the brake and look straight up. You'll see the fog light relay switch. It's a black relay plugged into a clear plastic harness. If your not sure which one it is, just turn your fogs on and off, and you will hear it click.
Then cut the red wire coming out of the harness. Make sure you leave plenty of wire going into the relay, you will have to connect a wire to that later. Tape off the red wire that's not connected to the harness, were done with that.
Next, take out the plastic cover that's on the very left side of the dash. The one that you can only see when you open the door. It's immediately to the left of the fog switch. There are four push tabs holding it in. Just pop those tabs out and then it will pull right out. You will see a wire harness plugged into the fog light switch. You will need to tap into the black/green wire. Don't cut it, just splice into it. Then connect a spare wire from that black/green wire back down to the red wire going into the relay switch that you cut earlier. That's it. Took me about 15 minutes.
