Its a sexy video.. but if you look at a lot of the outsdie shots.. there seems to be a ton of body roll round the corners. I saw a bit of 3 wheel cornering as well. It's definitely shot and edited to make the car look good, but I'm not convinced my 2 couldn't outrun it on the track as delivered. 0-100km time is impressive tho.
The 50-60hp gain sure would be nice for coming out of corners though, and in stop and go traffic I could really use it too especially when being stuck in 2nd on any kind of incline -- studder, studder, drop to 1st ZOOM... plus the steering wheel looks awesome and for some coin the Recaros sure would be sweet.
You don't think the 2 will 3 wheel even with coilovers? Seems like even the b-spec cars 3 wheel when really pushed hard... isn't that just a fact of life with a torsion beam rear end and stiff chassis? Would the Focus 3 wheel less?
Which Focus? The ST has independent rear suspension.. stock, I'm not sure if it'll 3 wheel.. set it up stiff enough, and it will (although, you shouldn't set up your suspension based solely on how much height you can get it off the ground).
Yeah, I meant the ST -- I was just wondering if even with the independent rear suspension if it would 3 wheel if it was stiff enough -- I thought so based on what I've seen at auto crosses -- it was just a thought I had after watching the Fiesta video. So no, I don't plan to set one up just so it can 3 wheel, lol. Thanks for the info!
I'm gonna be honest here, I didn't see much body roll, FWIW. 3 wheeling, especially in the rear, means that the rear is setup up stiff(er), which in a FWD car, is fastest (if you can drive it right)... essentially. Now, are you saying stock for stock, the 2 could beat it? Or your car now vs. stock ST.. cause even that, same driver driving the cars, the ST I believe will still be able to beat the 2.
I'm almost certain, especially with the way the B-Spec cars are setup, there will be 3 wheeling happening. B-Spec cars (AFAIK.. anyone else with knowledge can chime in) are setup stiff in the rear.. they need to be to carry momentum through the corners, since power is lacking in that series.
Ford also had a demo day to show off the handling of the Fiesta when it was new. They had an autocross course set up with a bunch of competing cars. At least one of the competing cars was not allowed to be driven because Ford was afraid it would roll over. Yeah, right..........
John
