if you had 10W-20 oil that would be one thing, mabye some slow starts in the winter.. but since this is 5W-30 we're talking about, it's going to run thicker when the engine is up to operating tempreature vs 5W-20,which means parts are going to be less lubricated and that's never good..if you're anal about oil changes like me and do your 3K changes every 2.5K... then you'll be fine and just get some 5W-20 next time.. but if you like to streach out oil changes to 6,7,8-10K... then just run up to the store and get some 5W-20..you'll only need 3Qt or so.silvermz3 said:I read my manual and it recommends using 5w - 20 motor oil for my 2.0 liter mazda3i. I have 5w - 30 oil in my garage. Is it safe to run on 5w - 30 oil?
TheMAN said:but use that oil ASAP if that has been sitting on the garage shelf for a while because oil can thicken due to the cold
