I was wondering if any one has the same problem as I do with the 2014 CX 5. I have around 2k miles and it seems like its consuming some engine oil, coolant fluid has been dropping a bit and brake fluid as well. Fluid were not top off when the car was brand new and the dealership said it doesn't need to be top off. However, from day one, the coolant fluid from the reservoir has been dropping a tiny bit at a time and the dealer said it should be normal. From my other mazdas, none of them ate engine oil or have any loss of coolant fluid unless the car was over 100k miles. Was wondering if this is normal.
Kind of concern why the brake fluid would drop as well.
Also, is it normal for the engine fan to be still running when the car is turn off? It happen to me once the other day, the fan just keeps running after the engine is shut off. The fan runs about a minute or so and then turns off it self.
