and i also know that your running bigger injectors, did you just plug them in or did you have to enter them into the support tool (where it divides the stock size by the new size and then give you the correction calibration) so it would calibrate for the larger injector? if you did put them in the support tool do you remember what the stock injector size is in cc's.
thanks again
thanks again
