p5T said:There should just be four wires for the ignition harness. (two for each coil). Not sure what p/o pic your using, but the one I used it was all on one page.
p5T said:Same one I used. ON page 2 left side is a pic of the 12 pin ignition harness
Pins 26 and 52 are for the coils. One is red the other is white.
A. CUT THE WIRES.
B. Then ON THE RED WIRE you connect 1in to the ecu and 1o to the red wire leading to the coil(away from ecu).
C. Then ON THE WHITE WIRE you connect 2in to the ecu and 2o to the white wire leading to the coil(away from ecu).
Plug into EM.
Good luck!![]()
i just downloaded it to the desktop and then extracted it to a new folder and then cut it and pasted it in the support tool folder.p5T said:I updated straight from 1.11 to 1.25.
Are you sure your saving the downloaded file in the temp folder, then copying it to the TRUST file (inside the program file) then extracting (extract here)? After extracting click 'yes to all' it will overwrite the older version files...
I currently have this version running on win95, 98(2nd ed), 2000 & XP...
brealmp3 said:ok i still couldn't get it to update to v1.13 so i hand programmed the maps with the profec e-01 so i didn't use the computer. but the car runs now, but it won't idle i have to keep it above 2000 rpm to keep it running. if i let off the throttle it will die. does anyone know what that may be? i also have two cel's one is p0102 and it is maf low input signal and then i have one that is p0103 which is reading maf high input signal, anyone have an idea on what might be causing this also?
tekkie, how exactly did you wire in the resistor on yours for the maf? cause when i called greddy they said it's not needed unless it is an rx-7. and on your air flow adj. map what do the numbers going down the left side mean. they go like 0 3 6 10 15 and so on.
thanks
