R Rotus Member : 07 MS3 Apr 21, 2010 #21 HBD! Mine is coming up, maybe I should go ahead and order it. Did you have to drain the coolant or were you just due for a flush?
M Mid_Life_Crisis Member Contributor : 2007 MS3 Apr 21, 2010 #22 Rotus said: HBD! Mine is coming up, maybe I should go ahead and order it. Did you have to drain the coolant or were you just due for a flush? Click to expand... You need to drain some of it because removing the egrv exposes a coolant jacket. I ended up under the car pulling the lower hose over a large funnel. I still refuse to believe there was no dedicated drain.
Hank3 Asian Persuasion <>< Contributor : 2010 Mazda5 GT Apr 21, 2010 #23 Someone posted an excellent "How-to" on cleaning the EGR for the MS3 on a different forum. Just saying...
