The e-brake light indicator on the dash lights up intermittently when pushing the brake pedal. It will then go off when pushing the gas pedal.
Brake calipers do not appear to be seized.
must be fluid induced.....i wore a set of hawk pads down to about 2 mm had no brake light......but the resevoir was always kept full. but yeah, pad wear will lower the fluid level pho show......
