Driver side mirror rattle/vibration
I own a 2025 CX-5. 1st drive notice that the driver mirror vibrates over 60. it was replaced. didn't really change anything. any ideas how to solve this issue? maybe contact the DMV report them about this issue? looks like Mazda knows about this issue but sadly, wont do anything about it. ideas? Tnx...Tom
The attaching bolts are behind the door covering. Pull back the covering, using a small blade screw driver.
Hi, poasting this again. if anyone pls can help. 2025, turbo, auto folding mirrors. driver side mirror vibrates at highway speeds.
unfortunately it is a common issue with no apparent fixes..my 23 tubo has done it since new...just a very minor vibration but enough to fuzzy up the images..
as i am outside of US, pls open a case with the fedral viacle motor. i cant from here. i will not take it that a new car has a safty risk issue that forcing me to be unable to look at the driver side mirro! it is fuzzy, right from the center. i took apart the glass, used some black tape on the bolts, but nothing. its not from there. the mirror is very hard and i cant even move it i made it so hard to move just to check. point is i cant tell if it cuz of the wind at high speed or if its getting somekind of road vibrates at high speed. funny thing is , just the driver side. the other side is ok. i have written today a hard letter to mazda over here and i will take it to court here as it seems to be a world wide defect. i will ask for your help with opennong a case.
pls do it for all of us. https://www.nhtsa.gov/
It is not even close to bad enough that i feel it is a hazard. My crv did the same.
