twiztedjeckel
- '04 SVT Focus
SpicyMSP said:I got the back end to swing out
i bet you did didn't you(upbum)
Drifting is the fastest way around a corner! If you do it right that is... When you drift your wheels are supposed to keep spinning at almost the same speed you enter the turn so when you exit and regain traction you can leave at a high speed.
Its basically impossible to do a convential drift with a FWD car. On entrance of the turn, you turn the wheels towards the corner and then turn them back outwards, facing away from the corner, that way all the wheels slide in harmony
The only way drift in a FWD car is to control the understeer with the brakes (left foot braking drift) Oversteering does not help you for all the idiots who said you "oversteer" to drift. Oversteer makes you 'plow' and basically your car follows the path of the weight, which is not good.
Hitting the brakes will you give you mild-oversteer and pulling the hand-brake slightly up throughout the turn several times will allow you to get the same effect in a FWD car as in a RWD or AWD car without using the wheels to slide sideways in conjunction with the back wheels.
HADA 11 said:
Riiiight. Find some information about racing lines. I;m sure you'll be suprised by terms line slow in fast out. Try reading the inforamtion posted at http://www.miata.net/sport/Physics/
You can maintain a racing line while drifting and yes I know about slow in fast out...Ive seen races where fools have drifted corners and smoked people in times, but thats on multiple turns in a row.
We can drift around turns but its not really considered drifting:
"With a front wheel drive both the power and countering wheels are up front so it eliminates the possibilty of drifting grouped turns. A demonstration would be taking a rwd car and finding an open parking lot. Get up to a good speed and then just yank the steering wheel back and forth and you will start fishtailing. This can not be done with a ff and and drifitng is almost like fishtailing around turns. Of course this doesn't mean that you can't take your ff and throw it around turns because you can. Dave of Slide Squad does it pretty successfully with his Civic but the fact of the matter is that it's not drifting. A term that has become pretty popularized from the Velocity BBS is ass dragging."
Wicked cool video, to bad its down.spoolinmp3 said:
(stupid)HADA 11 said:redmption,
Post a link to your sources. I really need to learn about slide squad.
Are you confusing slip angle with drifting? I cannot imagine a circumstance where drifting around a corner would be faster than driving a racing line. I realize you could drift following the same path as a racing line, but that's not the same as driving the line.
Slipping and sliding is not the right way around a racetrack.
No. That's not how you initiate a drift.
You approach the corner much slower than you would if you were racing. You turn into the apex semi-abruptly and lift the throttle. This shifts the weight from the rear wheels to the front wheels. Since the rear wheels are unweighted the lose traction and the rear of the car rotates or slides. You control the drift with the throttle. If you're rotating too much you apply the throttle to shift the weight back to the rear to get more traction.
The steering inputs are to adjust the attitude of the car, not to violently break the car loose.
You actually have that ass backwards.
Understeer is the plowing or "not steering enough"
Oversteer is the car rotating or "steering too much"
Left foot braking is a way to induce oversteer.
It depends when you apply the brakes. Hitting the brakes mid corner could cause something much more drastic than "mild-oversteer". The hand brake locks the rear wheels causing them to loose traction. It's usually used is slippery conditions to avoid flatspotting the tires.
HADA 11 said:For the 3rd friggin time.
YES IT IS POSSIBLE TO DRIFT IN A FWD CAR!
And by drift I mean all 4 wheels sliding and the driver controlling the car via the throttle and steering inputs. Not a slight drift either, a sustaind drift with the car sliding about 45 degrees off line.
It isn't practicle to use a FWD car for "drifting" but that doesn't mean it impossible. I don't understand what torboage means by "simulating a drift". Either you are drifting, or you are not.
I can't believe what passes as tech on this board.
Never said it wasn't possible. Just takes the right setup.
Well, from all the drifting i've seen, at least 2 of the wheels have traction. How are you supposed to control a car without something gripping the road?
Not really, go watch some real drifting videos, if you look....all of them are RWD, although some are 4WD(skyline) but we all know that a skyline is mainly RWD until you "drift". That is REAL drifting.
I've yet to see some real hardcore FWD drifting like that, you know why? Because front wheels spin and are for steering input, the rear wheels only follow. If you lose control of the front wheels you are understeering, if you lose control of the rears you are oversteering.
And are you the resident technician?
Instead of popping the clutch or gassing it hard while dropping a gear to put a RWD car into a drift, in a FWD you have to carry a lot of speed or make sudden jerky movements on the steering wheel.........or ...... use the e-brake (although I've seen plenty of professional drifters in RWD cars using the e-brake) to get rotation to occur.
