DEPO Headlight Replacements
my depo one sucked, as i stated earlier in this thread they had capa certification (which basically means it is of oem quality) until 2 years back on p5 headlights so their older ones may have been made better the 2013/14 ones. In mine the bulbs just did not fit well, the low beam spun in its mount even with metal spring down and turn signal did same thing. the high beam mounted well but the mount was bad as i could see light through the "seal" around the high beam. it also leaked water really bad. any moisture in the air would cause water in that housing to get worse. my shop replaced it with mazda oe from dealer for me free. i would stick with those, even though they are expensive, its worth it!
