I am having some problems with the final step - i.e. progrramming. Before that, in terms of installation I found it relatively easy - the hood part and the cabin part.
1 tip:
I had trouble getting the ground nut off. The tip is: use a 2nd. nut. The bolt protrudes from back so I attached the ground connector and a 2nd. nut. Tightened it good. No need to take off the bolt!
Registration - even after following all the steps it did not work. Now, every time I am trying the car's dashboard is reporting "Ignition is On" message. This is appearing after the Start button being pressed with the key-fob twice. The car/security light keeps blinking also.
Is there a way to reset everything and start again?
When I use the RS key-fob to start the car, A2 error message is displayed - which as per user manual means registration failure. But, when trying to register - I am having the problem above.
