DIY CX-5 Factory Remote Starter - Install and Program
Remote starters even 5 years ago were, "Oh wow, please, no, don't do that!". Today, since the widespread use of "T-Harnesses" where you no longer have to cut even one single factory wire in the harness, the installations have become trivial.
Unclick factory harness at the prescribed connectors
Click T-Harness between the factory connectors
Click T-Harness to remote start brain box
Program
Enjoy
Yeah, but it's not that simple - you still have to remove stuff to get to the connectors then route wires and mount the device, all while lying on your back with your head stuffed into the driver's footwell and your feet dangling/cramping up. And don't forget about attaching some wires that don't go through the T-harness.
Agreed it's not the complete hack that it used to be, but still.
Thanks for the detailed guide. I didn't put the OEM Mazda starter in but an idatastart. However I did still install the OEM hood switch instead of the basic one supplied with the idatastart. Much easier and cleaner.
thanks for the guide, just installed, got everything working, programming instructions were easy enough to follow, already had the hood switch thankfully since my car is canadian
Searching for 2013 cx5 remote start compatibility with any phone link system brought me here where my question is not answered. I doubt this factory remote starter will connect with a phone link but hope someone finds a way.
