Cryo Cooling = More power?
does anyone know if there is a way to or if even possible to set this up to the stock IC?
Just used my setu, same that Pirana has the NX intercooler sprayer. Well I tested it when the car was relatively cold and ran out of nitrous rather fast since I had sprayed several times for the cool factor before the install. Wi'll be re-filling it and seeing what happends then at the track or after several uses.
All in all, it's a damn nice mod as far as looks. White smock filling up your grille. Mucho hotness....
dangit I really want to know if this will have a significant effect on a smic and if it will fit. someone with deep pockets should be generous and do some R & D for us poor guys (kissass)
Pirana said:
Allright guys....I just received my NX N-tercooler set up and also with an Autometer intake temperature gauge I will be able to see what the intake temperature differences will be with the NX set-up. I will be heading to the dyno within the next week. Will keep you posted.
NX-wooohooo!!!
Any updates Pirana? What license plate did you go w/ or did you change?
Not changed yet...I do still enjoy the SLO plate :D I overheard a guy at the last show, "slow my ass",hehehe, it was all worth it.
have not filled my bottle yet...so probably next week when it gets a little cooler here I will dyno. Right now is over 100 degrees everyday.
Is the temp gauge hooked up yet pirana? Just curious if you had any readings.
Jeffmsp- I was just curious if your still running water/alch injection and how long did your tub/washer tank etc. last before you had too fill it up again.
Sorry to stray off subject.
No N20....sowy
n20 as well!!
maybe i should remove my last 2 posts as well!! :) (posts in bumper as seen above btw)
co2 seems like itd be more practical since its widely available and not as expensive as nitrous. i really wanna do a sprayer but i need to get my car running right before i do mods like that. but yea lookin good pirana, why two solenoids?
it's my understanding that c02 is a lot cheaper than nitrous and both are efficient, but co2 is a very dirty. you'll notice the residue difference at the car wash b/w n20 and co2.
