Cruise Control
If I had to guess a failure I would say the clock spring in the steering column opened up. Look at the wiring diagram and see if you can jump the two wires that go to the switch before they go into the column. Could be brake or clutch switch, vac leak or module itself. pick a place and start troubleshooting.
