Having both they are no where close to each other....but you knew that already.(flash)shadow1 said:Corksport will be releasing a catless downpipe and an axleback muffler system (retains the stock midpipe/2nd cat combo). A 3900 lb SUV will likely never be able to run with 3200 lb Evos and STis. The MZR motor just doesn't make more power than a 4G63 or EJ25 respectively.
Veddy Niice!!MadMax1 said:Ill add CX-7 little modded, and a 00 Subi Imp Rs with 06 usdm wrx engine swap![]()
MadMax1
shadow1 said:What turbo are you running in the RX? Greddy kit?
www.cp-e.com said:Well thanks a lot for your input guys, this is exactly what I'm looking for. We need to know if you guys would consider a turbo swap, and it looks like that's a little more headache than you guys are willing to endure, which is fine. Now that we know this we can concentrate on optimizing the stock turbo setup.
We still have to dyno tune BadakVT's (Mike) car, so we still may gain a good amount of power over the stock tune. Mike said that the car feels stronger with just the boost control enabled at 16psi, but we still need to tweak the timing and air/fuel. So we're going to try to get him on a dyno soon.
Jordan
Rick's CX-7 said:Jordan,
Put me in this group too! Turbo swap might be too much....optimizing the stock set-up will be much more appealing to most of us here.
Also, check out this link http://www.mazdas247.com/forum/showthread.php?t=123673527
Don't know if you know much about oil analysis, but it seems your assumption that the CX-7 might be "pig-rich" like the MS3 and MS6, is true. Those two oil reports are from my CX-7 and it's not looking good. Massive amounts of fuel being dumped "directly" into the chambers is not a good thing. Thankfully, wear doesn't look to bad. I can e-mail you the two full reports if you think it'll help!
Rick
Jordan,
Rick
I'll probably be one of the few considering a turbo upgrade in the future. I don't think I'd mind raising the boost threshold a few hundred rpm to gain a lot more in the upper end. Until that time though, I'd love to make the current setup perform as well as it can.
Excellent! I think we're going to be releasing some bolt-ons for you guys in the near future, so you'll definitely have some product choices to help maximize the performance potential of the current platform. I think we'll have some more significant updates in the next couple weeks.
Jordan
