thanks for the response and all the hard work! I am curious, the wastegate solenoid position signal you are measuring...is that basically wastegate duty cycle measured from the boost control solenoid (bcs) itself? If so, that could be an erroneous reading since that is more a function of the ECU to the bcs
signal, and again in a 2 port bleed system, even at 100% duty cycle, it usually cannot bleed enough so that the wastegate maintains shut. i do agree that they inlet (and maybe even outlet) a/r may be prohibiting the higher boost, but without inhibiting all the other restrictions (exhaust/intake/boost-wastegate control) out of the equation, it is hard to deduce how much it has effect on it. however, i am no expert on the MZR series of engines, just giving some feedback on the work i've done on Evo's.
QUOTE]
A good MBC would answer this question very simply. Plus a MBC would eliminate the bleeder system OEM setup. You can keep the wastegate shut until 15 psi is actually reached rather than trying to bleed off the boost pressure that the wastegate sees from the stock BCS. And a MBC would completely eliminate the ECU portion of this equation. If boost still drops off, then we know that it is a limitation of the turbo itself rather than any ECU trickery. Although I'm still convinced that the e-throttle being pulled by the ECU is not helping matters. You can feel this effect when you floor the CX7. The engine power drops off momentarily prior to the tranny shifting. The CX7 actually runs to 60 quicker if you DON'T floor it. At like 80-90% throttle, the CX7 ECU does not seem to pull the e-throttle prior to shifting.
