Those are my top 2 as well -- prices have come down - and I stay consistent on the brand and refill locations knowing when they changed the underground tanks last--were under $3.50/gal-for 91 now so Costco dosent beat that by much at least here - Texaco comes in #1 which is Chevron......however on my 2.5 2010 Mazda NA MZR engine -- it does well on anything so I use Costco for that guy ---but the high compression CX5 gets temperamental if I start swapping brands and octane-In my area costco is ok gas to get you from A to B. Shell and Chevron are better but cost more.
Source : obdii monitoring and personal feel for the cars.
Ever run Philips 66? That's our primary station here with 91, and my car always runs really well with it.In my area costco is ok gas to get you from A to B. Shell and Chevron are better but cost more.
Wow, you're right! I didn't realize that!Costco is "top tier" gas that I've used almost exclusively for 20 years or so with nary a problem!
Unfortunately dont have that. Only shell chevron costco and the smaller franchises like quicktrip and circle k. Wish we had 93 but sadly only 91.Ever run Philips 66? That's our primary station here with 91, and my car always runs really well with it.
At high altitude there isdriving steady rpm and steady slow acceleration one could probably drive on 85 if there was any.
I have pretty cool route options where I live (TN valley). Lots of hills, rural backroads, and my home is on a small mountain with couple hairpin turns. I was hoping to notice some sort of difference with 87 vs 93 with “spirited” mountain driving but man, I just don’t. That’s not disappointing though, it’s amazing what Mazda was able to pull off with this design. I’ve never found the performance to be lacking!driving steady rpm and steady slow acceleration one could probably drive on 85 if there was any.
Sudden heavy acceleration from low rpms and lower speed is where it matters how and what fuel is used. i.e or when the engine is at its highest load. This is usually where knock and lspi happens and ignition has to be top notch.
in Montana it is somewhere around elevation 4500' or so gets 85 for regular..you see it quite often.At high altitude there is![]()
And Colorado.in Montana it is somewhere around elevation 4500' or so gets 85 for regular..you see it quite often.
