CorkSport Mazda 2 Short Ram Intake
Yes i also noticed this issue but the clamps only fit in a certain way, if you follow the instructions i think its one of the smaller clamps it says put around the filter to the intake body, which doesn't quite fit, honestly it took me 10 minutes to see which clamp went where, just look at it and you can see it don't go right lol
Chris
I just need to know the correct size of the clamp on the throttle body. your packing list and your instructions say two different things.
The clamp for the throttle body is the 63-71mm size.
Chris
Did you have a problem getting the clamp started? Did you take the nut off the clamp to install it or try sliding it on? I just want to understand so we can make adjustments.
-Derrick
You'll probably want to change this in the install instructions then:
"One of the 3 inch clamps goes over the MAF housing side of the coupler, and the other 3 inch clamp goes over the other side of the coupler." (Second sentence of Step 2 Section B)
I will get the engineer to change that.
Thanks
-Derrick
I followed the instrcutions but the clamps were wrong, i ended up redoing it myself after basically looking and seeing it didn't fit lol, i think the quote from your instructions writen above are correct as to where i noticed something wrong lol, but otherwise i had no issue with the intake calmps, once i got the right ones in the right place :D
Chris
