Is there a discount for customers buying both the Corksport down pipe and the exhaust at the same time?CorkSport said:S-pipes will be available seperately @ $189
lcruz64 said:Is there a discount for customers buying both the Corksport down pipe and the exhaust at the same time?
lcruz64 said:anyone knows if there's a dyno sheet for the turbo-back setup?
fkmitsu said:penis
RXMmazdaspeed said:fa fa fa fa fa faaaagina
slug420 said:yep....you will need tiny hands and a open ended box wrench where the end of it is bent off to the side. If bestbuy didnt lose my camera when i brought it in to be cleaned i would have posted a pic by now of where the impossible bolt is to get off and put on and you will have a good idea of what the wrench needs to look like.
If you have the s-pipe then bring it into sears with you and hold a wrench up to it to see how it fits (or how it does not fit as the case amy be) and you will get an idea of what to look for....getting your hand up there is another issue.
The only dyno sheets are on the website on the Unichip. I'll have to double check though.anyone knows if there's a dyno sheet for the turbo-back setup?
E mail me.Is there a discount for customers buying both the Corksport down pipe and the exhaust at the same time?
(mswerd)CustomMSP said:So has anyone installed one yet?
Thanks.
