skippyracecar
- 2001 Mazda Protege MP3
I've replaced my control arm 3 different times with no luck! I'll get the ball joint into the knuckle nice and tight, wheel attached, no movement left/right/up/down. Then I put the car on the ground, jack it back up, and bad movement left to right. I can see the ball joint wiggling back and forth inside the knuckle but it won't tighten up any tighter.
Could it just be a worn out knuckle or is there anything else it could be? I've replaced the control arm (3 times), wheel bearings, tie rods, just about the entire front end! PLEASE HELP!!!
