hmm...that's weird...i thought the stock boost level for ms3 is 16, but according to my defi boost gauge, I am peaking at 19.
my guess is you spike to 19 and hold 15-16
Stock boost is at 15.6 PSI...
I guess it would be possible to increase boost with an intake (mine never did) since you are unrestricting the flow of air.
What kind of temps are you driving in?
I am driving in cali, where temp has been cool for the past couple weeks. I have Bov that is not re-circ. so maybe that has something to do with it.
Many others have put on aftermarket BOV's and noticed slight boost increases as well as faster spool times. 4th 5th and 6th also usually have higher boost than 15.6 even completely stock. What gear are you noticing the higher boost levels in?
3rd gear around 16, and 4-5 gear at 19.
I have an MS CAI and an MS CBE and my boost levels are unchanged from stock as I also have a boost gauge.![]()
Since I was the lead designer to the MS3's ECU coding and have substantial knowledge in relation to your question, the answer it quite obvious.
Your turbo needs to be recharged.
