Cobb AP Discussion Thread
Tune finally settled. Over 300 miles.
I'm not really looking to mess with anything either. If it wasn't done by an expert, I'm not letting my monkey fingers mess with it.
I would just try a Stage 1 93 map for now. You may need to look into an intake to gain more from your car.
I took your advice and switched to the stage 1 93 oct map from mzdspd.com and its working a bit better. With the griffin tmic, i was getting off boost, part throttle knocks a lot... with this 93 map, it pretty much cured that... the problem is still the same when it comes to boost spike though...
its shutting me off about 4500... i hate that feeling... so in other words, i wouldnt be getting on it for the next two weeks until i can get a tune...
I wish I could have someone sit down and show me in person how much to lower the values under the wastegate duty cycle map. My tuner said that should solve the problem... Also, under help in the ATR i found an explaination of what each catagory is/does
Something is off. Since the tune has settled my s*** is running real rough. I just filled up and got 17mpg without any ripping on the car. I average 21-23 all the time.
All the connections on my TIP are good, nothing seems to have fallen off or slipped. (shrug)
Retuned to Stage 2 SF+93, running more like what I was getting.
Is it possible I broke my stock BPV with the extra power? The whoosh when I let off the gas doesn't sound the same. Used to be a crisp whoosh-psssss, now on the pssss side it sounds more rough like it's going through a big plastic airbox.
Well, I don't think the "extra" power had anything to do with it, but it does sound like you have a leak somewhere. If you've had the BPV off, the gasket is likely rolled...
Ok, so the mzdspd stage 1 93 oct map took away the part throttle knocks but the car is still getting fuel cut...
here's a pic of my log... this was a quick 2nd gear pull to figure out what was going on...
you can see around 5100 the car gets fuel cut...
You might be due for fuel pump internals or a HPFP.
whoops... forgot to mention.... i have fuel pump internals... KMD version 2's
car had plenty of fuel pressure until it hit cut...
pressure hit 1800 psi
my car was @ 15psi around 5100rpms... the fuel cut looks as if its set to kick on at 17.8 psi @ that rpm depending on the barometric pressure... im in jax FL so we are pretty much sea level... i guess i'll log Baro pressure next time to see if that plays a factor
Heads up, all the new v1.01 maps, along with the firmware updates are available right now on the Cobb website.
Bova, you gonna have other maps on your site like usual?
hey steve, should i upgrade to the latest firmware? i saw the highest was 1.4.0 on the cobb website... what are you using?
I just updated my firmware, and my AP manager software as well. I recommend updating everything right now, just to be safe.
I've not had a chance to look at their updated specs. Please be sure to post if/when you have the chance to play with the flat foot shifting and launch control and how easy it was to program for it.
Ok, here's the million dollar question: How do you enable LC and FFS with the new maps? Is this based only in ATR, or is it something that we have to wait for in a new map later on?
EDIT: from the release notes, looks like it's enabled/set up in ATR
Title: AccessPORT & AccessTUNER Updates for MAZDASPEED3 & 6
Summary
Several enhancements have been implemented on the MAZDASPEED3 & MAZDASPEED6 AccessPORT platform.
  • Launch Control and Flat Foot Shifting have been implemented in AccessTUNER Race and AccessTUNER Pro
  • MAZDASPEED3 maps up-reved to v1.04
  • MAZDASPEED6 maps up-reved to v1.01
  • DTC P0421 Catalyst Efficiency has been disabled
  • Several software bugs have been addressed
  • New firmware has been released
Please note that in order to take advantage of all of these enhancements, AP Manager must be updated to 1.2.1.0, the AccessPORT firmware must be updated to 1.4.0.0, maps must be updated to MS3 v1.04 and MS6 v1.01 and AccessTUNER Race must be updated to 1.7.3.0. Additional details and instructions regarding these updates are shown below:
AP Manager 1.2.1.0
AP Manager must be updated to version 1.2.1.0. Download AP Manager 1.2.1.0 here.
AccessPORT Firmware 1.4.0.0
Firmware must be updated to latest revision to take advantage of all enhancements. Firmware 1.4.0.0 includes the following enhancements:
  • Federal and California models now treated as one model
  • DTC P0421 defeated in all Stage 2 and Stage 2+ maps
  • Expanded MS6 maps database
For Firmware Update instructions, please visit the Mazda AccessPORT Firmware Page and follow the Step-By-Step Instructions.​
AccessPORT Maps Up-Reved
Maps for the MAZDASPEED3 and MAZDASPEED6 have been Up-Reved. They are available for download in the MAZDASPEED AccessPORT Map Database.
Please note that in order for these maps to function properly, the AccessPORT Firmware must be updated to 1.4.0.0.
MAZDASPEED3 v1.04 Maps
Stage1: Adjustments made for more consistent boost control. Map saved as new format that is compatible with new LC/FFS features
Stage2: Adjustments made for more consistent boost control and defeated MIL (see below). Map saved as new format that is compatible with new LC/FFS features​
MAZDASPEED6 v1.04 Maps
Stage1: Adjustments made for more consistent boost control, boost, fueling, and ignition changes for additional power improvements. Map saved as new format that is compatible with new LC/FFS features
Stage2: Adjustments made for more consistent boost control, boost, fueling, ignition changes for additional power improvements, and defeated MIL code. Map saved as new format that is compatible with new LC/FFS features
Expanded Map Database
  • Stage1 93 Octane
  • Stage1+SF 93 Octane
  • Stage2 93 Octane
  • Stage2+SF 93 Octane
AccessTUNER 1.7.3.0
Several important enhancements have been made to AccessTUNER software for the MAZDASPEED3 and MAZDASPEED6.
  • Launch Control and Flat Foot Shifting are supported and allow the end user to configure LC RPM and and FFS RPM in the map.
  • Updated Tuning Guides with Launch Control and Flat Foot Shifting sections are available for download on the MAZDASPEED3 and MAZDASPEED6 AccessTUNER product pages
  • DTC P0241 defeat is configurable
  • Bug fixes
    • Fixed camshaft phasing scalar
    • Fixed problem wit Boost Dynamic table not saving
    • Conversions fixed in following tables
      • Boost Comp - Baro
      • WG Duty - Baro Comp
      • WG Duty - Battery Comp
      • WG Duty - IAD Comp
    • Fixed ranges for Boost Table target values
Professional tuning facilities requiring the MAZDASPEED AccessTUNER Pro updates should contact Scott Brood at 801-713-0443 or wholesale@cobbtuning.com for download information.​
AccessTUNER Race users can download the updated software by visiting the MAZDASPEED3 AccesTUNER Race product page or MAZDASPEED6 AccessTUNER Race product page and click the DOWNLOAD button. Fill out the resulting survey, complete with vehicle Make/Model/Year information and the AccessPORT serial number. Please allow up to 24 hours for the notification that your software build is complete and ready for download.​
Happy Tuning!
Gary Sheehan
COBB Tuning
I just flashed my car to Stage 2 93 v1.01. No driving specs yet, just wanted to see if I could configure the LC and FFS, but no luck.
I would imagine it is an option you have to enable with ATR. Again though, I'm at work and haven't looked at their revised specifications.
I sent in my request for the new ATR, we'll see if I get it and what it entails.
I was hoping it was similar to how the Suby's get it, using the cruise control buttons on the steering wheel to adjust it.
I just updated everything last night. Went to hook up my ap this morning and its saying my dongle is outdated. Told me to unplug it and plug it back in. I am still getting this. Ill try to update it again and see what happens..
